Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 21.10.2015, 07:51   #406
CyberStorm
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
likhrus, какие минусы? Сплошные плюсы в аппаратной замене. Процент остающейся старой жидкости сравним с раздельным сливом из радиатора и блока или даже меньше будет. И быстрее в разы.
Старый 05.11.2015, 07:58   #407
cepreu.m
Аватар для cepreu.m
день добрый! Вот в принципе нормальная замена LIQUI MOLY 8841!
cepreu.m вне форума   Вверх Ответить с цитированием
Старый 26.12.2015, 13:33   #408
cartmanes
Аналоги по составу 1:1
cartmanes вне форума   Вверх Ответить с цитированием
Старый 31.01.2016, 17:20   #409
acetodol
а ктонибудь пробовал такую штуку (FELIX 4606532005030
Антифриз "EXPERT", 1л) заливать на добавку. просто сам нахожусь не в россии,выезжать домой надо. а в местном экзисте в наличии нет нихрена...все ждать неделю. ( с картинки выше атрикулы пробовал)
acetodol вне форума   Вверх Ответить с цитированием
Старый 31.01.2016, 20:18   #410
Спокоен
Я залил FELIX G-11 Green,проехал более 2500 км,проблем не замечено.
Спокоен вне форума   Вверх Ответить с цитированием
Старый 12.02.2016, 08:38   #411
cartmanes
В составе G11
-Ethylene glycol 107-21-1
-SiO2 силикаты
-Denatonium benzoate 3734-33-6
-Disodium Tetraborate 12179-04-3
В составе SLLC Premium
-Diethylene glycol 111-46-6
-Potassium Hydroxide 1310-58-3
-Proprietary Inhibitors NJTSRN217
В составе SLLC
-Sodium benzoate 532-32-1
Старый 12.02.2016, 09:24   #412
CyberStorm
@Спокоен, вообще проблемы с охлаждающей жидкостью не могут возникнуть за 2500 км. (если конечно она не замерзнет зимой). Даже если вы несоответствующую зальете. Это достаточно длительный процесс, который больше растянут по времени чем по пробегу.
PS. Я не к тому, что вы неправильную жидкость залили - просто 2500 пробега не показатель совершенно. Вот через 6-12 месяцев если пойдет коррозия блока тогда будет понятно
Старый 12.02.2016, 12:36   #413
offskid
Авто: Outlander XL 3.0, Honda Civic 5D 1.8
Взял на земену - Антифриз HEPU P999-005 5л (G11) синий.
offskid вне форума   Вверх Ответить с цитированием
Старый 12.02.2016, 16:33   #414
Спокоен
Сообщение от CyberStorm Посмотреть сообщение
Если зальете жидкость несоответствующую ,т.е. не совместимую ,с заводской,то вспенивание или муть появится сразу-100-150 км,т.е. после полного смешивания.Такое бывает-занимаюсь ремонтом машин на СТО.
Старый 12.02.2016, 17:38   #415
CyberStorm
@Спокоен, ну это если частичная замена проводится, а я, например, менял методом вытеснения на аппарате т.е. старого антифриза осталось в системе пренебрежительно мало. Соответственно в этом случае проблемы возникнут через длительный период.
Т.е. тут будет проблема не в совместимости между антифризами, а во взаимодействии с металлами.
Старый 12.02.2016, 17:52   #416
Спокоен
Сообщение от acetodol Посмотреть сообщение
Был задан конкретный вопрос-я ответил.Что я не так написал,или я не так прочитал вопрос?Где говорится про полную замену ОЖ?
Старый 12.02.2016, 18:03   #417
CyberStorm
Все нормально в вашем ответе, я просто уточнил, что 2500 км. это очень маленький пробег для оценки. Если было бы 25000 км. пробега, то вопросов вообще никаких не было. По полной замене ОЖ возник вопрос, т.к. вы указали на хим. реакция между несовместимыми антифризами при неполной замене, а при полной замене на маленьких пробегах появление хлопьев от смешивания ОЖ практически невозможно, там только коррозия со временем элементов двигателя из за реакции с металлами.
Старый 14.02.2016, 10:20   #418
cartmanes
Ещё premium - Chrysler 68163849AA только цвет фиолетовый
Старый 28.02.2016, 19:04   #419
Anatoliy83
Всем доброго времени суток! Сегодня менял антифриз на своем Ауте III 2.0 и все бы не чего НО слил я с радиатора и расширительного бочка всего порядка 3л даже потом продувал, во общем чего я только не делал но больше и капли антифриза с аута выдавить не смог. Залил нового естественно заранее приготовленного тоже где то получилось 3л завел движок и все в порядке.
Мужики подскажите где я потерял 4,5л антифриза?
Anatoliy83 вне форума   Вверх Ответить с цитированием
Старый 28.02.2016, 19:10   #420
androder
Сообщение от Anatoliy83 Посмотреть сообщение
В блоке цилиндров, в радиаторе отопителя.
androder вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 10:39. Часовой пояс GMT +3.
